calling Cartman!!!
Re: calling Cartman!!!
Originally Posted by snakeatinZ
Josh, What did you say to do with a steel driveshaft to beef it up? Something about welding this or that??? I deleted the pm on accident.
Thanks man.
Steve
Thanks man.
Steve
They told me the stock shaft in good shape will hold 400-500 HP. So just have new u joints installed, check for runout, balance, and have the slip yolk welded if its leaking. Then you're good to go.
Originally Posted by Josh'95Z28conv
I had the slip yolk welded because it was leaking tranny fluid out the center. It didnt make it any stronger or anything. I had it balanced, and straightened. It had .010" of runout I believe, which weakens it a bit. Also have the u joints replaced. The stockers are plastic injected to hold them, instead of having snap rings. The stockers can also be off in alignment.
Steve
CARiD
Sep 30, 2015 05:44 AM
