Brake light problem, need help!
Old Dec 31, 2004 | 02:01 AM
PonyStalkerZ28's Avatar
Question Brake light problem, need help!
I am having problems with my brake lights and was wondering if anyone could help. My problem is that my SS spoiler is the only one that DOES work, the tailights dont. At first I thought brakelight switch but then thought it couldnt be that if the spoiler brakelight works, cause none should work if it was the switch. Could it be the switch, or something else? Any help is greatly appreciated.
Brenden
Old Jan 1, 2005 | 04:14 PM
Re: Brake light problem, need help!
yeah I replaced the bulbs, and I am pretty sure the tailights are wired with the spoiler also.
Old Jan 1, 2005 | 07:56 PM
1BAD80-Z's Avatar
The brake lights go through the turn signal switch , the easiest way to check it without five pages of electrical diagnostics , is to buy or borrow a t-signal switch and plug it in under the dash and see if it works then , if so , then you've found the problem !! ( it's usually the culprit )
Old Jan 2, 2005 | 01:32 AM
ElkyRacer's Avatar
Theres a thin long connector under the steering column, its about 3-4 inches wide. Thats some of the brake lite connectors, it sometimes rattles loose a bit. Try plugging it up some more I had to take a zip tie and tie around it to make sure it wouldnt rattle loose again.
Kyle
Old Jan 3, 2005 | 06:22 PM
Thanks guys, I appreciate the help. I will check those things out.
Old Jan 8, 2005 | 12:10 AM
Kyle
I messed with a black connector that was about that wide and like a half inch thick and it fixed the problem.
Thanks guys for the help.
Brenden
Old Jan 8, 2005 | 05:59 PM
ElkyRacer's Avatar
No prob. Glad you found it.
Kyle
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
