Anyone need some raw carbon fiber?
Old Jul 1, 2007 | 09:01 PM
the spindoctor's Avatar
i've got a crapload of it i need to sell, so if you've got a project, let me know!
the fiber is braided together all the way around in a circle, much like a chinese finger puppet. you can cut it lengthwise down the middle and have a flat sheet, the width being the circumference of the circle. so an 8" diameter piece would be roughly 25" wide (2 x pi x radius) and i can cut any length needed until i run out. it'll stretch quite a bit, but what you gain in width is lost in the length and vice versa. its neat stuff if you know what you're doing with it.
6" 45 deg 14.4 oz/sq yard ~18"wide when cut $6.00/ft
6.5" 30 deg ??? oz/sq yard ~20" wide when cut $6.50/ft
8" 45 deg 11.0 oz/sq yard ~25" wide when cut $8.00/ft
12" 45 deg ??? oz/sq yard ~37" wide when cut $12.00/ft
18" 45 deg 13.9 oz/sq yard ~56" wide when cut $18.00/ft
Old Jul 2, 2007 | 10:56 PM
1965GP's Avatar
Hmmm... what to make.
When I was doing stereo's we would wrap things (Anything!) with this and a can of 3M spray Adhesive. Then, use clear tabletop coating to give it a finished look.
If I knew it would hold up in the weather I would do all the trim on my GTO.
Old Jul 6, 2007 | 03:27 PM
69MaroConv's Avatar
What project did you buy it for?
(free bump)
Old Jul 8, 2007 | 04:05 PM
(free bump)
we used to use it at work to make tubing, but don't do that anymore and this is the leftover old stock from about 5 years ago. i'm in the process of trying to make some bodywork for my racebike that i crashed 2 weeks ago, so we'll see how that goes.
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
TGGodfrey
Aug 17, 2015 08:43 PM
Aug 5, 2015 08:35 AM
