Anyone got some drag radials or slicks I can use for 2-3 passes?
My drag radials on my pro stars starting showing the wear bars. Want to make a couple more passes before adding the 1.6 rockers and the tune.
Come on fellas!
Come on fellas!
DR's at the wear bar should still hook for you. BFG's are awesome when all the tread is gone. I pulled 1.47 on M/T's two weeks ago that are beyond the wear bars. I stopped using Nitto's when I went to 3:73's and 3000 stall years ago in my old T/A.
If you want to come out to Redline sometime maybe I can hook you up. They are only running on Sundays right now.
