100 LL airplane fuel
Re: 100 LL airplane fuel
Originally Posted by Greed4Speed
The questions is also, are you modded enough to actually need that high octane fuel?
Ryan
Don't know how it would affect the rest of the fuel system, I meant you can run with no O2's thats no biggie or cat. As for fuel lines/injectors not sure. I think they'll be fine if cleaned every so often. Those airplanes are all carbed so no high pressure fuel injectors. On the other hand, you would think the injectors/pump will like it since it lubricates unlike regular gasoline.
Yes, 100LL has lower levels of lead than previous aviation gasolines. However, its still has a large quantity lead. You will get a way with mixing it with the gas you nomally burn once in a great while. I would not make a habit. You would be better off using a octane booster or race gas. I have cleaned many airplane spark plugs. You would not believe how loaded with lead the plugs get with in 50 hours of engine operation.
Jim
Jim
The main difference between avgas and auto gas is what's called "light ends" avgas doesn't have many. If you took auto gas up to high altitude, where the ambient pressure is low, a lot of it would evaporate. Avgas doesn't evaporate at alt. as easily. It's additive package is different also, but it's still just gas and has been used by high performance buffs for years after the changeover to unleaded.
ramair96ws6
Oct 18, 2001 08:22 AM
ramair96ws6
14
Oct 17, 2001 10:43 PM
