wont shift 1-2 unless you let off gas?
Old Nov 5, 2004 | 01:13 AM
charkly's Avatar
ok guys-heres the deal-95 auto camaro, 3.4 auto. car drives fine, but it wont shift from 1-2 without chopping the throttle-or letting off completely until it shifts-all other upshifts and downshifts are fine, doesnt slip or anything under any circumstances-just holds first until you back down-not sure what it could be, check engine light came on once when i beat the hell out of it, but went out once it was shut down. car has 111k, owned by a little old lady since new-its had this problem for quite some time, but i just picked it up. thanks for the help. Mike
Old Nov 5, 2004 | 07:15 PM
charkly's Avatar
Re: wont shift 1-2 unless you let off gas?
upon closer scrutiny it appears as though it skips 2nd altogether and goes right to third-skips it on downshifts as well? thanks, mike
Old Nov 8, 2004 | 06:56 PM
Chrisz24's Avatar
Check your Transmition fluid level,
My old Z24 had that problem, sometimes it wouldnt want to up shift at all! it was choppy shifts and sometimes no shift, in turns the fluid washes to one side of the pan so it didnt have any then either, dry gears!
~Chris
VF-124
Mar 16, 2015 08:14 PM
blac94Z
Jan 12, 2015 05:44 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Rbain
Sep 4, 2002 12:35 PM
simple
Aug 11, 2002 11:56 AM
