Wiring HelP
Old Aug 6, 2002 | 09:12 AM
CARdiac's Avatar
Question Wiring HelP
am by no stretch of the imagination an electrical engineer or an electrition.....So I need some help.
My pass side window is going down very slowly but goes up fine...it does not matter which switch you are using, same result. The motor is new so I eleminated that possibility. I suspect the wiring or the relay. Now I looked at the wiring diagram and now I am thoroughly confused. Does the pass side have a relay and where is it? Does the DS signal pass thru the PS switch? Does the signal from both switches pass thru a relay and then go to the motor? If the signal goes from the switches to a realy then to the motor, can I install an instant down like the DS?
Please help. Any advice is very welcome
Old Aug 6, 2002 | 01:06 PM
94BlackBowtie's Avatar
Post
I had to replace my driver side window motor twice before it worked right, so don't rule out that the motor you bought was a "GOOD" one. If you got it from AutoZone or Advance Auto then it was probably a remanufactured one, and they don't always work right. You may want to check and make sure you got the harness plugged in good, but I would say that it is still a motor. Take it into the parts store you bought it and beat them in the head with it, then they'll listen
Here's the page for the Express Down passenger window, thanks to Brent (Brent94Z)..mod for the LT1 tech...
http://www.bfranker.badz28.com/fbody/expresswindow.htm
I've got '94 F-Bodies, with items strategically placed to increase the performance and appearance.
Old Aug 6, 2002 | 01:31 PM
CARdiac's Avatar
Post
Actually when the problem started, I replaced the motor (twice) under warrenty. The motor is not remanufactured, it is new. I still think it is the wiring.
Old Aug 6, 2002 | 01:48 PM
Post
Oh well, I'm not sure what else it might be then, only thing I would know to do is to run down everyhting that is coming into the motor. It will take a little while, but unless anyone else has an option, that's what I would do...good luck. That Autodown window guide is nice eh?
[This message has been edited by 94BlackBowtie (edited August 06, 2002).]
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
