will 25th anniv. intake , air plenum fit my 95 3.4l
Old Dec 11, 2003 | 10:15 PM
95camaro3400's Avatar
ive got someone giving me intake manifold and air plenum off a 25th anniversary rs. will they fit on my 1995 3.4l? i believe the engine is a 3.1. ive heard these heads flow better , should i go for it? thx
Old Dec 12, 2003 | 12:53 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
i have no idea what the manifolds on the 3.1L f-bodys look like , but it will most likely bolt up... im not sure about clearance, but it should bolt to the engine
also the heads wont flow any better than the stock 3.4L ones, they are all the same gen I iron 60* V6 heads
Old Dec 13, 2003 | 12:19 AM
MustangEater82's Avatar
I am pretty sure they will fit, but like said doubt it will be any bette then a 3.4L setup...
do you have any pics of it? I not sure what a 3.1L setup looks like, but I know what 2.8L FI setups looked like.
By the way I you will have to plug the distributor hole since you don't have a distributor and the 3.1L did.
DirtyDaveW
Dec 1, 2016 05:37 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
95chwagon
Jan 13, 2015 09:19 PM
