What should I replace next?
Old Apr 28, 2012 | 02:54 PM
Evolution223's Avatar
I've got one of those $50 advanced auto parts coupons, but dont know what should I do with it if anything?
the car is a 2000 v6 camaro with 101,000 miles, it has never broken down, I want to keep it that way,
the maintainence is totaly up to date, i've done all the mods I want, all filters & fluids are new, & it runs good, just replaced alternator, cat, PS pump, ICV, MAD sensor is cleaned reguraly, battery, plugs & wires,
was thinking of getting one of these..., they are all orginal on the car.
NewCoils
EGR valve
starter
AirConditioner pump
Fuel Pressure Sensor?
or something else???
What is most the common to break? I want to prevent having a break down if possible. Else I would just let this coupon expire and wait for the next thing to go out.
Old Apr 28, 2012 | 05:31 PM
Re: What should I replace next?
I think I want to replace the fuel pressure regulator....but i found out how much work it was so i wont bother
http://www.ls1lt1.com/forum/v6-tech/...regulator.html
Old Apr 29, 2012 | 09:56 AM
daytonablackZ28's Avatar
Definitley egr valve or invest seriously in a k&n filter. U can clean the egr though so u might not need to change it. U might want to change the fuel filter too if you havnt already. The k&n filter is a real good idea not cause u want performance but the car will be able to breathe so much better hence less load on the engine and better fuel economy. Also, DEFINITELY run synthetic motor oil if you are not already.
KYWes
Apr 15, 2015 05:48 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
stopthatman
Feb 9, 2015 09:00 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
