what is normal oil pressure for 3800 v6
Old Dec 23, 2006 | 03:00 AM
jimmy3fan's Avatar
Hey guys, I was just wondering what normal oil pressure is for a 3800 series engine? From what the gauge reads it is around 60. When I got home from work tonight I could tell smoke was coming from under the hood by the headlights. When I opened the hood under lights if there was smoke there shouldn't be alot of it. I guess if I am losing oil I would assume the pressure would be low as well. What does anyone think?
Old Dec 23, 2006 | 02:32 PM
2000GTP's Avatar
If you have an external oil leak and it is making its way on the exhaust manifolds for example causing smoke, it still won't cause a dip in oil pressure. Pressure issues would result from a malfuntion internally such as bad/worn out engine bearings. I would look under the hood and try to see if you can visually locate an oil or even a coolant leak and go from there.
Old Dec 30, 2006 | 05:09 PM
FloydSummerOf68's Avatar
Pressure should be around 60-70 under acceleration and mine drops closer to 45-50 at idle.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
jayblev95
Dec 1, 2014 06:55 AM
