Valve Lash - please help
Old Aug 18, 2003 | 07:07 AM
MillerTym's Avatar
Hey everyone I'm new here. I've got a 93 3.4 Camaro and I figured this would be the best place to get some help. I just replaced both head gaskets after warping one of them. Both were also milled .05 I believe. I started it up yesterday and it is running real rough and I'm almost positive it is because I tightened the rockers down a little too much. I did the ol turn the push rod till you feel lash method and then I set the preload. Here is where I have the question, my service manual says to turn it 1.5 turns past lash, but with heads being milled I'm guessing I went a little to far. Anybody else used any other methods that would help me out? Thanks.
Old Aug 25, 2003 | 10:02 PM
faddis's Avatar
does the 3.4 have hydraulic lifters? i would say one half turn past the lash and you should be good...
Old Aug 26, 2003 | 07:11 AM
MillerTym's Avatar
yeah, it has hydraulic lifters. I adjusted them all again turning it 3/4 turn past lash and it might have helped a little. I'm beginning to wonder if that is even the problem. The car will start and idle, barely, but it basically has no power. On this car you have to remove the upper intake, fuel rail and injectors, TB, and electrical connections before you can even take the valve covers off. There wouldn't be a need for longer push rods would there? I really didn't want to have this towed into a shop, money is kind of tight right now, any more ideas?
Old Aug 26, 2003 | 09:21 AM
faddis's Avatar
hmmm maybe a vacum leak or something like that...if its idleing rough...? lacking power...uh did you check all your plugs wires ect. make sure your fuel injectors are in all the way and sealed good...i had that prob after a valvetrain rebuild...my car wouldnt idle at all...just a thought???
Old Aug 26, 2003 | 09:46 AM
MillerTym's Avatar
I made sure the injectors were seated and the plugs in all the way. I recently put new MSD wires and platinum plugs on it, maybe there still could be a problem with one or more of them after sitting around a while. I'll recheck all of what you mentioned. I appreciate the help, feel free to let me know of anything else you think of.
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
