V6 guys need ur help on something...
Old Aug 7, 2002 | 01:03 AM
MeaN-GreEn-3.4's Avatar
Exclamation V6 guys need ur help on something...
Tomorrow morning i am going to take off the cat, after i unbolt it and take off the clamp does it just slide off or do i need some special tool? and should i take the o2 sensor from the old cat into the new pipe? and one more thing would i still be able to use the old clamps that was on my old cat? help me out guys, thanks
1995 camaro 3.4 A4
K&N filtercharger
5 Spoke chrome rims off a 2000 z28
Xlerator performance exhaust
GTS blackouts (rear)
Kenwood Excellon Deck
Old Aug 8, 2002 | 01:49 AM
camaroKID's Avatar
Post
will it slide off?- no, rust sucks.
special tool?- hammer
new O2 sensor?- yes
slpurge for those new clamps too.
i cant remember if there is something else holding the cat on!
chris - got to keep the maro!
-94 3.4L A4 camaro, 15.84 @ 87,
-other car- 1973 plymouth satellite,built 360.
-brand new old car- 1978 L82 corvette, slightly modded
-Plymouth site
-general pics of my life
-camaro site
[This message has been edited by camaroKID (edited August 08, 2002).]
Old Aug 8, 2002 | 01:53 AM
MysticTeal 95 V6's Avatar
Post
I was able to get the bolts off fairly easy... just took a lil extra cursing and banging but I made it out alrite
Like camaroKID said... replace the sensor while you're at it. Be sure to either squint like hell while you're under there or wear goggles. I don't think your eyeballs are very good friends with rust flakes
Old Aug 8, 2002 | 05:46 PM
fourthgen9534's Avatar
Post
use some good anti-seize lube, and u won't have a problem gettin em out next time
Red '95 camaro. 3.4l M5
Crane compucam2030 K&N FIPK. Flowmaster catback. Hurst billet plus shifter. ASP crank pulley. !cat !egr !air TB bypass. 1pc. D/S. Taylor wires. Fan switch mod. urethane Tranny mount & TQ arm bushing.
Red painted interior and brakes. Tint. Flat black rear "camaro" panel
Pioneer Premier DEH713 HU
Planet Audio 6 1/2 components.
mtx thunder 102
16.37@84mph<==1st time at the track
here she is
Old Aug 9, 2002 | 01:13 AM
MustangEater82's Avatar
Post
yep also have to unhook the exhaust hanger clamp. jsut some bolts, elbow grease.
As for getting the CAT off the I-pipe, I spun it in a slight circular fashsiopn and it came off jsut tok some patience.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Rapidfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys, 160* stat
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
15s are cool!
AIM: MustangEater82
carguy0119
Apr 11, 2016 11:11 PM
Red97LT1
Aug 7, 2002 05:45 PM
ced8
Jun 24, 2002 11:11 AM
