Urgent Help Needed *Overheating*
Old Jun 11, 2004 | 03:45 PM
JB_96RS's Avatar
I have a 96RS that seems to be gulping coolent!! I don't see it leaking anywhere and there is no indication that of coolent in the oil. Where could it be going?? I can also smell antifreeze when it heats up.
Thanks,
JB
Old Jun 11, 2004 | 04:58 PM
JoshMcMadMac's Avatar
It's not leaking into the car through the heater core?
Old Jun 11, 2004 | 05:23 PM
JB_96RS's Avatar
Checked that... but after letting it heat up I looked underneath and there is a steady stream of coolent dripping off of the skid plate near the front of the car?! Does this sound like anything major (headgasket??) or is more along the lines of a hose? I just started this 2 days ago.. I changed the oil and it looked fine. I can't get a good look at where it is dripping from.. I think my RS needs a lift kit!!!!
Old Jun 18, 2004 | 08:30 PM
deadmeat2004's Avatar
mine did the exact same thing, iut turned out to be a freeze plug had a tiny whole in it.
BUT if it only leaks occationally when it starts to heat up then its your water pump i bet. Might try to see if thats it.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
MJ_Z28
Aug 7, 2002 07:15 PM
mjcent922
Jul 27, 2002 12:42 PM
