transmission problems
Old Apr 7, 2007 | 08:53 AM
Garcia95's Avatar
last night i went to the island that is about 1and a half hours of driving. on mi way back i noticed that the tramsmission was slipping a lot so i stoped at a walmart and cheked the fluid the car needed some so i bought some and putit in. the transmission worked for a moment, but as i was driving it would start slipping and i had to pull over a couple of times. so i ended up at my grandmothers house and left the car there. so has any of you had a problem like this? by the way its a 95 camaro with a 3.4L v6. what kind of transmission does the car have, and what are the stock gears of the car.
Old Apr 7, 2007 | 09:01 AM
mdacton's Avatar
post in the drivetrain forum, the trans vendors would give a a good responce
Old Apr 8, 2007 | 10:26 AM
2000GTP's Avatar
You have a 4L60-E tranny. As for the gears, you'll have to check the RPO codes in either the door jamb or glovebox and compare:
GU2 = 2.73
GU5 = 3.23
GU6 = 3.42
warmeck
Mar 16, 2015 07:02 AM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
edxiel
Jan 24, 2015 07:40 PM
Cam's maro
Dec 28, 2014 09:30 AM
