TPS sensor...worth it?
Old Aug 17, 2002 | 11:08 AM
blue95's Avatar
Post TPS sensor...worth it?
only downside could be running some seriously bad emmissions at high rpms and could this screw my computer up by messing with the throttle like that?
http://cgi.ebay.com/ebaymotors/ws/eb...954369&r=0&t=0
If you own a V6 Camaro or Firebird you need to be here!
http://www.fbodyv6.com/index.php
Old Aug 17, 2002 | 03:16 PM
NeoPaladin's Avatar
Post
I've seen these before. What they do is that at a certain percentage of throttle application (looks like 50% for this one), they tell the computer that the car is running at full throttle, and adjust the timing as such.
Will you see a performance gain? Midrange, yes, you will. But not in terms of peak power, like you would with a true computer chip, which changes timing and fuel curves throughout the rev range.
If you're set on getting one of these, you can get one through Jeg's, I think. A company called Caspers Electronics makes them.
1994 Black Firebird 3.4L
Mods include:"Ghetto Master" K&N FIPK, Crane 8MM Plug Wires and Accel Coil Packs, ASP Underdrive Pulleys, SLP Take-off Shocks and Struts, Edelbrock Performer RPM Catback, Catco Hi-flo Cat, 1 pc. steel DS, built GM 4L60E transmission.
Founder of the Free Aqua M&M's Society
Track Times (only FIPK).
E/T: 17.209
MPH: 77.326
Proudly posted!
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
