tempted to get some bolt on SFC
Old Aug 7, 2003 | 09:52 PM
Chrisz24's Avatar
Everyone has weld on ones but I really have no means of geting them welded around here and I would like to be able to take them off if I switch cars down the road.
Anyone have experience accross the bord? V6 &V8 applications?
I was thinking if I needed to I would upgrade the nuts to self locking &use lock tight if the fear is them coming undone.
~chris
Old Aug 7, 2003 | 09:56 PM
kacy's Avatar
i had aslp dd bolt on sfcs and didnt have a prob with them most people think they just screw into the frame but the dont you actuall put a solid metal block in the frame through a preexisting hole and it threads in
Old Aug 7, 2003 | 09:58 PM
Chuck!'s Avatar
If you really want them buy bolt ins and have them welded in later on when you find someone to do it. I paid $75, Im sure you can find someone around you to do them.
Old Aug 7, 2003 | 10:06 PM
SSpdDmon's Avatar
I'd say go fer it. I've been looking to pick up a set of bolt-on sfc's here...
http://www.spectaclesolutions.net/
Old Aug 7, 2003 | 10:43 PM
lbrowne's Avatar
I have bolt on SFCs and I love em
Prolly going to get em welded later on though
Old Aug 7, 2003 | 10:50 PM
ATMINF's Avatar
I have a set of the bolt on type from SLP. They have been on my car for several years and I check them every no and again. They have NEVER loosened up. One other advantage to the bolt on SLP's is that they came powder coated while the weld on type did not.
Old Aug 7, 2003 | 11:11 PM
GrdLockV6's Avatar
I got BMR sfc's welded on for like $30... personally I'd just get them welded. If you end up changing cars, they can be cut off. When I sold the car they were welded on I took it back to the exhaust shop, and had them cut them off for $20. No biggie, I then sold them to a friend for about $100 heh.
Old Aug 8, 2003 | 06:08 AM
baron4406's Avatar
Where do you live in NJ??? I live about 45 minutes from Jersey, in the Allentown area. I'm a welder if you need that work done. As far as romoving them, you can but not as easily as bolt in ones naturally.
Old Aug 8, 2003 | 07:42 AM
Threxx's Avatar
FWIW, there are two brands of SFC for my car (actually they are called lower chassis braces, but it's the same concept)- TRD and Tom's racing. Both brands are bolt-on only. I mean I guess you could weld them on if you wanted to, but over at the lexus forum nobody has even considered such a thing, as nobody has ever had a problem with them loosening up.
Old Aug 8, 2003 | 07:52 AM
96_Camaro_B4C's Avatar
I'm glad someone asked this. I'm probably going to do some SFCs in the near future. Everyone says they really tighten things up (and my car is still remarkably tight for a 92k mile '96 - mostly freeway miles helps). I've had a few people say the bolt in kind won't really do anything, which seems wrong to me. All sorts of subframes and crossmembers are bolted to the cars...
Those who have bolt-on sfcs (or have in the past), did you notice a real difference compared to no sfcs? Do they tighten up the car nicely? I'm not looking to race my car (at least not yet); I just want to tighten her up a bit, but have the ability to return to stock. Any thoughts?
Old Aug 8, 2003 | 08:29 AM
Shockwave's Avatar
Lounge Moderator
Moving to V6 Tech Forum...
Craig
Old Aug 8, 2003 | 08:46 AM
Huh? This isn't a V6 question... It applies to all 4th gen cars. That includes V6, LT1, and LS1, right? The original poster even asked specifically about both V6 and V8 applications. Could you at least put it in LT1 tech where it will get the most exposure?
Old Aug 8, 2003 | 09:15 AM
Chrisz24's Avatar
ok, while this is still somewhat floating....where is the best place to get them? I found a place last night but forgot where it was
Any sugestions?
Old Aug 8, 2003 | 09:32 AM
1fastV6's Avatar
BMRfabrication.com
Old Aug 9, 2003 | 08:57 PM
Greed4Speed's Avatar
I don't know why people are afraid of bolt ons. If you think about it, all your major suspension parts are bolted on. Just use some loc-tight and go with it.
HarleyZ28
Oct 5, 2015 06:23 AM
maybe2fast
Mar 16, 2015 09:45 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
rje
Sep 9, 2002 12:35 PM
jakeSS
Jul 22, 2002 06:54 PM
