TB Bypass for 3.4?
Old May 28, 2003 | 10:26 PM
Snoman73's Avatar
TB Bypass for 3.4?
Hey guys, i was just wondering how i do the TB Bypass for a 95 3.4? also what are the pros and cons of doing this? cooler runnin engine?
Old May 29, 2003 | 12:01 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
there are 2 coolant lines running into the bottom side of the TB(on the 3.4L anyway). all you do is disconnect them from the TB and then connect them together.
pros- the air charge entering the engine is not quite as warm due to the lack of hot coolant running thru the TB
cons- in winter (in cold regions) the TB may get more hesitant to open and close.
personally i dont think that it could really make much of a difference in how the TB opens and closes, but it is on there for a reason, so apparently someone thinks that it should be there
Old May 29, 2003 | 12:37 AM
MustangEater82's Avatar
go for it I doubt it woudl cause any problems in Alabama.
Old May 30, 2003 | 02:01 AM
blkmaro94's Avatar
I'd say put on that tb bypass. It's so simple. To me I don't know about everybody else. But I can feel the difference it makes. I switch it during the summer, and back during the winter. because out here in utah, hot as hell during the summer, cold as as a mother during the winter. but yeah, easy as switching up two hoses and your done. NO KIT REQUIRED.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
