sub frame conetors?
Old Nov 25, 2002 | 08:20 AM
Chrisz24's Avatar
sub frame conetors?
I was wondering if this would be good for my car, it is now going on 5 years old with barely 20,000 miles on it and everything rattles or is loose, (I bought this car in january with 10,000 so I dont know how it was driven before me) I love the handling and feel of it but I was told that sub frame conectiors would help improve the strenth of it and should also be on it because it is T tops and not as strong to begin with.
Since I dont have a welder I would need the bolt on ones and I am still unsure where they would go? I am pretty firmilure with the under body and what is there.
Is it worth it for a car as old as mine, would anything noticeable be felt? would the handling improve?
Old Nov 25, 2002 | 08:49 AM
MustangEater82's Avatar
Should make a difference stiffens up the frame, may affect the rid a little bit, if that is a problem. Its not really going to tighten things up that are coming loose, it will make it handle better though.
Get weld ins they will be much more effective and see if you can find performance shop locally to install them for you, I would think that is the easeiest route. FIthey have worked on 4th gens woun't be hard for them its a common mod.
Old Nov 25, 2002 | 04:51 PM
blue95's Avatar
Its hard to say if it will take care of all the rattles....it really depends on what they are.
Its worth going weld on's over bolt ons. Bolts on can wear down....but if you are wondering where they go check out the sites that sell them....www.bmrfabrication.com tybrne.com etc for pics.
But if you are going for any other suspension mods then get the sfc's. It will strengthen your chassis for any others upgrades.
Old Nov 26, 2002 | 01:54 AM
chesee48's Avatar
ya i'd denfinetly get weldin...and if i were to get ones...i'd get the Kenny Brown DD's...ithink they are way better then the BMR's , yet that are like 2 times as much =)
but i believe if u are gonna do it once, do it right
Old Nov 26, 2002 | 02:47 AM
1fastV6's Avatar
you love the handling of your camaro now???? handling in camaros sux imo, untill you get subframe connectors. i recommend bmr100%.
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
Aug 5, 2015 08:35 AM
