starter problem....
I am sort of busy so I will keep it short
tropical storm eduarti(whatever its called) flooded the area, I am usually pretty good at avoiding deep puddles but one surprised me, I drove thought i normal stuff like belts, and brakes working like crap for a bit. Well about an hour later when I started the car, thye starter sounded like it whirred a bit with out hte car cranking, I stopped and started it againa and car cranked and started.
drove to where I had to go and it had the smae problem, so I started the car, let it heat waaay up doo to an unrelated cooling fan problem. then dorve soem more, then pakred, let car heat up again, then shut it off. I am hoping its something simple like water shorting a connection, and maybe the heat, will help dry it up.
any ideas, other then replace starter?
-Eric
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Stock blocked, boltons only.
15.696@86.22 with a 2.214 60'!
Best R/T .507 Best 60' 2.078
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
3.4L F-body where 15s are fast....
www.fbodyv6.com
www.firebirdv6.com
www.camaroz28.com
AIM: MustangEater82
-Eric
www.fbodyv6.com
www.firebirdv6.com
www.camaroz28.com
AIM: MustangEater82
Well, it probably wouldn't hurt to at least pull the conn's to make sure they AREN'T the problem, then just tighten em back up, that way you know that they are good...you may even wanna pull the starter off and make sure everything seem ok with it..I know water pulled the front fascia off my bud's car one time when he hit it to fast, so make sure there's nothing freaky going on that you can fix. But, most likely, you're just looking at a new starter
clean the connections with a wire brush and put them back on......tight! its a bitch to get to the connections, but its more of a bitch to replace the whole thing, beleive me!
good luck eric!
chris - got to keep the maro!
-94 3.4L A4 camaro, 15.84 @ 87,
-other car- 1973 plymouth satellite,built 360.
-brand new old car- 1974 L82 corvette, corvette orange, 4 speed.
-Plymouth site
-general pics of my life
-camaro site
good luck eric!
-Plymouth site
-camaro site
Once it dried out, its worked great this morning. And every start since then.
thanks for the help though.
-Eric
www.fbodyv6.com
www.firebirdv6.com
www.camaroz28.com
AIM: MustangEater82
-Eric
www.fbodyv6.com
www.firebirdv6.com
www.camaroz28.com
AIM: MustangEater82
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
