Is this the "SPARK PLUG" Problem?
Hi, any help from you all would be great
O.K. So here's the description of my problem.
I have an Automatic V6.
If I'm in PARK or NEUTRAL and I hit the accelerator, at 3800 RPM
the engine starts to jiggle and dance and the tach won't hit 4000 RPM. However, when I'm driving in the city or highway I don't have this jiggle problem and the RPM will go past 4000 to red before changing gears
Any thoughts
Horde
Any thoughts
Horde
i certainly hope the rev limiter is not at 4K rpm.
have you pulled codes?
im having issues myself, and goin through this same sorta deal. ive narrowed it to ignition related, but that is about it.
is it the same hot or cold? ignition parts on the outs often tend to show their problems once they get physically hot.
just my two cents. good luck.
Yeah, your right, whats the point of reving in neutral or park?
The only reason I did this was in the winter time. I store the car during the winter season. Every couple of weeks I'll start it up and play with the trottle. When it happened this past winter, I blamed it on the cold. But when spring hit a friend of mine was egging me on to roar the engine. When I did it, the engine jiggled at 3900 rpm.
Well it doesn't sound like the spark plug problem.
Horde
Horde
charchri4
Apr 14, 2015 06:40 PM
grabbem88
Mar 18, 2015 01:25 PM
