Some goofy electrical/ECM problems...
Old Jul 5, 2003 | 03:31 AM
MustangEater82's Avatar
ey guys I am pretty sure I know what it is but its kinda goofy...
Alright ahwile ago my alternator to the battery wire was severely corroded, I yanked it and spliced in a battery cable. At the ssplice to the battary, the cover is slightly exposed.
The rpoblems my car has been facing, is occasionally the car will be running normal, then studder a little, radio will shut down and guages will go apesh|t,like bouncing between 80 and 120 when I am going roughly 45, and my tach will bounce between 5k and the 7k. but I am chiling at like 1500 rpms.
So do you guys think I am having ECM troubles? I am thinking not since my radio gives me trouble at the same time and I do not think the radio is in anyway linked to the ECM jsut sounds like a electrical problem maybe part of the wire is tapping the frame and grounding out to a minor short?
Sound about right to you guys?
Old Jul 5, 2003 | 09:14 AM
Bad Black 3.8's Avatar
I'm not quite sure what your problem is, but I have a similar problem. My tach goes crazy just like yours does! Sometimes it reads 0. Sometimes it jumps around like crazy. If I wiggle the wires where they enter the ECM, I can get it back to normal for a while. I think it's a bad connection on ECM. I'm too worried I'll screw it up if i mess with it though.
-John
Old Jul 5, 2003 | 01:26 PM
Hmm thats a thought of the connection being bad jsut to the harness(happened all the time on my 85 Camaro), thing that gets me though is the radio cuts out as well.
Well wouldn't surprise me, lots of moisture in the air in FL.
Old Jul 5, 2003 | 06:32 PM
wow, we joined around the same time, and look at the difference in posts...
Old Jul 6, 2003 | 02:11 AM
hehe and I didn't really start screwing around in the loounge until after they disabled post conts there.
I have rougly 4500 at anophter site, nearly 2500 on another and abot 1000 on 3 other sites together, so I ma pushing 13,000 posts, roughly since 1999
finn
Oct 17, 2003 10:06 PM
MustangEater82
Sep 30, 2003 12:09 AM
frmula1
Apr 30, 2003 02:07 PM
NowuZitnowudont
Mar 25, 2003 09:49 PM
