so what will high oil pressure do to a 3.4L?
friend nuked his engine so he put a "high flow" oil pump in his new 3.4L ... now when he's driving down the road the oil pressure is way past the dash gage.
what are the long or short term affects of very very high oil pressure?
Is Mike Pegging the guage?
has he tried another guage(Like his old one or the one that came with the motor)
He might get some leaks soon.
MY old 3.4L used to read pretty high, past 3/4 on cold but once warmed up about 1/2 and peaked to 3/4. This was with a new sensor, so it was accurate.
sure
yea its in orlando again
we scanned his car, the o2's were SHOT ... i mean, like almost dead, as was the IAT sensor
replaced them and its like driving a new car. no more hard starts, it was the IAT sensor!
Originally posted by anasazi
sure
sure
Originally posted by MustangEater82
haha.... well did you see it when drew pulled it out and it fell apart in 2 pieces? I thought to myself, "whoops thats not supposed to happen"
nope
his new one is like brass or something, its not going to fall apart
They ar not too bad... I did hte driver side one in a fw minutes, the passenger side I neede a little universal joint thing, for my wrenches hard to get torque on the wrech...
and you need a special o2 socket
Originally posted by morb|d
did you actually feel any difference after you replaced them?
I gained back .4(lost that much) in the 1/4, and went form 12/17 mpg to 20/25 mpg Course they were the stockers, that were 7 years old and had 105k on them.
i have no piston rings left in my towncar, and i have oil getting past my distributer into my rotor cap. i was told this was caused by the high oil pressure of not having good compression.
not 100% tho
not 100% tho
I just put a mechanical oil pressure gauge in my 88 Camaro. It's got a rebuilt 3.4L in it now..... warmed up and at idle it's ~50psi. Near redline is almost pegging the 100psi gauge. Motor has ~6500 miles on it and does fine. Hope that helps some at least...
-Bud
-Bud
