servise engine soon help me
Old Feb 13, 2011 | 06:55 PM
rk_2phat4u's Avatar
Angry servise engine soon help me
I went in and auto zone said.. 02 censor 6th spargplug misfireing evap leak or gas cap and EGR running at 10%... ok so i changed all plugs since i just bought the car.. new 02 censor on under driver side.. and cleaned egr valve... i dont knoew how to get that clip off my evap canister to evaluate it... so car sounds alot better but still cuts out bogs down dies.... its that evap some were cant find the control valve to check it either... and that 6th plug keeps misfireing.. pulled it out and it had black stuff all over it that happened a day later on new plug... what do i do??.. its a 3800 v6 1996
Last edited by rk_2phat4u; Feb 13, 2011 at 06:56 PM. Reason: plack was supposed to be BLACK
Old Feb 13, 2011 | 09:19 PM
rk_2phat4u's Avatar
Re: servise engine soon help me
92-96 EGR CONTROL SOLENOID FOR CAMARO is another part i need location for
Old Feb 13, 2011 | 09:40 PM
omega552003's Avatar
Wrong forum, this is the v8 LT1 forum, there is a V6 forum.
https://www.camaroz28.com/forums/forumdisplay.php?f=22
Old Feb 13, 2011 | 11:29 PM
ACE1252's Avatar
My brother and I have both owned 3.8 V6 Camaros. His was a 99 and mine was a 96. Both had the plug wires go bad. I also had to get a new EGR valve for his. I would start with getting new ACDelco plug wires for it. They can be a pain to route, but I bet that is your misfire problem.
If you are going to do work on the car, pickup a Haynes manual for it. That will help quite a bit. I always purchase the factory manuals for my cars(or find the factory manuals posted in pdf format on the net).
Old Feb 14, 2011 | 11:19 AM
rk_2phat4u's Avatar
ok thanks yeah i have a haynes for it... wires look good but i will get new ones thanks
Old Feb 14, 2011 | 02:57 PM
Guest47904's Avatar
Guest
V6 sorry
This needs to go to the V6 forum
Old Feb 14, 2011 | 06:07 PM
I'm not sure why nothing seems to get moved unless I do it, and this isn't even my forum.
Old Feb 15, 2011 | 02:30 AM
rk_2phat4u's Avatar
ok sorry for the wrong fourm.. but just so you know it was a coil pack......
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
