security doesn't allow me to start my camaro
Does any know how to bypass the security system to start my vehicle. When I attempt to start the car the security light comes on and my vehicle seems to be dead. I've tried both keys and get know were can anyone help me out.
Sometimes a wet or dirty key or if its not properly seated in the cylander it can cause that. If it comes on while your driving or happens freqently you most likely will need to have a new key cut with your VIN number at a GM dealer. There is a way to disable the system by putting a certain resistor in the line of the system, but i dont know the details on that procedure.
You could take one of the keys and your VIN# to the dealer. If the dealers decoder can't read the key then you give them your VIN#. If that doesn't work I would run a search on by passing it because I remember reading some one found out what resistance there key was (that thing in your key is just a resistor) then they went to radio shack and got the resistors that added up to the resistance on the key. You can add resistors to each other that way, example: 110ohm resistor+94ohm resistor+12ohm resistor=216ohms of resistance. The ohms are pretty low though on our keys and the resistors you buy to add up to that number don't have to add up to that exact number but be pretty close. Thats all I remember from that thread. I don't know where you hook up the resistors (would imagine some where in the steering column).
Gtpguy
Jan 26, 2015 04:50 PM
fpete1992
Dec 11, 2014 03:51 PM
