security dash light
Old Aug 6, 2003 | 05:11 PM
bckstr14's Avatar
security dash light
I/m having a problem with starting my 96 camero, when I place my key in the ignition to start, the security light comes on and will not allow me to start my car, afteer about 15 minutes it resets itself and light will go off and at that time I can start my car, this is an everyday occurance, can someone help????
Old Aug 6, 2003 | 05:14 PM
1fastV6's Avatar
my friends 96 security light is on all the time and we dont know why. but he has no prblem starting the car.
Old Aug 6, 2003 | 06:42 PM
Tiago's Avatar
this is related to the security system in the car, the key is wearing out. The small chip in teh key is failing. Get a new key or use your spare , should work. If not, then something inside teh mechanism is ****ed.
Old Aug 7, 2003 | 01:36 AM
kgkern01's Avatar
Would you have to take it to a dealer to check that out, or could an auto electric shop be able to do that? Has only done this since replacing new alternator and battery, right Chris?
Old Aug 11, 2003 | 10:56 PM
chris54991's Avatar
i get this problem with my '94 too, but its not 15 min. its only about five. i have a viper security system with remote start, and there is a device that bypasses the security so u dont need the key in ignition for remote start. occasionally the security light comes on even when i use the key, and it is a pain in the ***, but it rarely happens.
do you have an aftermarket alarm system?
Old Aug 11, 2003 | 10:58 PM
chris54991's Avatar
oh yeah, and electric diagnostics aren't cheap at most places (one shop here is like $80/hour), so if you do decide to take it to a shop, look around for the best price.
Old Aug 12, 2003 | 12:15 PM
kgkern01's Avatar
Well it is a co-worker's car, and I think he said he had a Viper alarm on it also.
Old Aug 12, 2003 | 01:13 PM
Brcarz28's Avatar
I had the same problem with my 94Z. I installed a turbo timer, so I needed the car to be able to run without the key in it. At first I tricked the VATS by taking a multi meter and checking the resistance of my key chip, then spliced in the proper resistors to match the same resistance to my key into the small wires that came form my key cylinder. That worked for a while but eventually my VATS fried. So I turned the VATS off with tuner cat and took the relay off which is located on the passengers side on the ouside of the glove box. It has four wires, purple, yellow, brown and a black and yellow. I cut the purple and brown wire and spliced them together, not the yellow and brown because then the car can start in drive or any other gear, and tada, no more problems with security lights, or starting the car. remember this will not fix the problem, but will disable it completely. Hope this helps.
Magenta_Hearts
Mar 29, 2017 08:54 PM
moparman
Mar 5, 2015 08:47 AM
warmeck
Feb 5, 2015 11:04 AM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
