SEAFOAM cured pinging!!! VIDEO!!
Old Oct 31, 2006 | 08:24 AM
Mr. Merk's Avatar
the ol 95 3.4 was pinging REALLY bad under load so we follow the instructions on treating the fuel system and the vac line method
cured all signs of ping!
all the crap that came out of the exhaust
http://videos.streetfire.net/search/...6b001aac47.htm
get on streetfire and search for seafoam!
Old Oct 31, 2006 | 08:26 PM
FunkZ's Avatar
Haha, really like the musical accompaniment! Did you have black stuff shoot out the exhaust too?
Old Nov 1, 2006 | 08:21 AM
Mr. Merk's Avatar
not that i could see.... but i was in front or in the car
well damn, she said its pinging again, gonna do it again but a little differently, i dont understand how it stopped and then started again
Old Nov 1, 2006 | 05:17 PM
FunkZ's Avatar
What octane are you running? Mine used to ping too with the stock thermo and stock tune when I ran 87, it would even do it occasionally on 89 if it got above 200°
I have run 92+ in my car practically since I got it, just to make sure I was getting the most performance out of it as possible. Since using the HPP now I run 93+, cheap 92 isn't even enough anymore to keep it from the occasional ping.
And yes, I regularly replace plugs, wires, use seafoam, etc. and my car has always done this the entire 9 years I've had it.
Old Nov 1, 2006 | 10:58 PM
Mr. Merk's Avatar
has 91 octane in it right now with a can seafoam mixed in
weird thing is it never used to do this, it started shortly after the cat install
Old Nov 2, 2006 | 09:03 PM
FunkZ's Avatar
That is weird. I could see if the old cat was clogged it could cause hotter temps and pinging, but shouldn't do it after putting a new one on. It's not running lean is it?
Old Nov 2, 2006 | 10:56 PM
Mr. Merk's Avatar
i wouldnt know why it would
if it doesnt work the 2nd time around i want to change the fuel filter and plugs, go from there
Old Nov 4, 2006 | 12:16 PM
GALIATHON's Avatar
Ive never used sea foam before, But i was told you were suppose 2 change the plugs and filter when your gonna use that stuff..
CARiD
Sep 30, 2015 05:44 AM
HAWG
Sep 25, 2015 11:41 AM
marlar98
Sep 19, 2015 07:53 AM
mark0006
Sep 14, 2015 12:35 PM
