Rough Idle/Stalling Help!!
Old Jan 11, 2004 | 05:56 PM
slayer6x6's Avatar
My girlfriend has a 97 camaro with a 3.8 in it. She broke down last night because her engine started running real rough and keeps stalling. I brought my scan tool and looked at it today and the only thing that looked wrong was that the computer was retarding the ingnition timing 30-35 degrees. The only way you can keep the car running is to keep it at around 3000 rpms. I couldnt keep it running long enough to get it into closed loop so I cant see what the oxygen sensors are doing. Any one have any suggestions on what elese I can look at?
Old Jan 11, 2004 | 11:18 PM
kmook's Avatar
Advanced Tech Moderator
General troubleshooting should be posted in a gen specific forum, transfering to v6 tech.
Thanks.
Old Jan 12, 2004 | 08:47 AM
deadmeat2004's Avatar
Was it running strong until then??
Old Jan 12, 2004 | 01:32 PM
slayer6x6's Avatar
I had driven it earlier in the day and it seemed fine.
Old Jan 12, 2004 | 01:41 PM
I remember reading something in this forum some where about the car basically shorting out and causeing everything to go crazy...could of jacked the computer up soemhow....i have no F'in clue??
Old Jan 12, 2004 | 01:58 PM
slayer6x6's Avatar
Well by the readings of my scan tool, the computer seems to be working correctly, but for some reason something is happening to make the computer delay the ignition timing so much. My guess is that it could be fuel related, but Im not sure where to go from here.
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
