Replacing Starter?
Old Sep 30, 2004 | 12:16 AM
Shorty95Camaro's Avatar
Replacing Starter?
My starter is starting to go on my Camaro. I honestly don't know much about this, but I'm wondering is this an easy swap if I put a new one in or is it too difficult to even bother and just take it to my mechanic? I like to learn new things but if it's impossible to get to or just not worth the trouble then i'd rather just take it to the mechanic. Any advice would be appreciated...thanks.
Mark
Old Sep 30, 2004 | 12:39 AM
camaros_4_lfe's Avatar
Re: Replacing Starter?
pretty easy just a few wires and bolts..go to autozone and look in the haynes manual if you want for the best way
Old Sep 30, 2004 | 12:43 AM
weak95bird's Avatar
this is the best way I found out on the 3,4l, haha I sat their fighting with that @#$% thing for hours then got pissed grabbed a jack and threw her under the engine and lifted it up a little bit gave me just the right amount of room to get that peace of crap in and out sliding it under the motor mount, good luck gab a few beers too helps out some times err almost all the time
Old Sep 30, 2004 | 09:36 AM
Thanks guys...so it doesn't sound all that bad...possibly worth a try.
I have the manuel but I'm at school currently...I only live about an hour and 15 mins from home...so i'll have to check that out next time. My parents were all paranoid that it was going to die on me...not that I should keep putting it off, but time to do something myself...
Thanks again,
Mark
Old Oct 2, 2004 | 09:57 AM
slammed95cam's Avatar
you HAVE TO jack up the motor..... the Y pipe is in the stupidest place..... its took 4 hours to do something that should have taken 30 mins..... make sure you you have the **** to shim it if needed....
Old Oct 3, 2004 | 02:57 PM
I heard something about it being in a ****ty place...I'm going to have to look at it this week sometime.
What exactly do you mean by jacking up the motor?
Also where is a good place to find a starter? I was just going to go to a NAPA or soemthing. How much will this probably run?
Thanks.
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Feb 5, 2015 11:04 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
