quickest 3.4s on the board in here...
Old Aug 11, 2002 | 08:22 PM
CLEAR's Avatar
Post quickest 3.4s on the board in here...
i know its been beaten to death but i need to know all the mods i can do to make my camaro the best it can be. i dont have much money (hence the reason i have a v6), so i figure i can make do the best i can and buy used parts.
Old Aug 11, 2002 | 08:47 PM
Ryan94V6's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by CLEAR:
i know its been beaten to death but i need to know all the mods i can do to make my camaro the best it can be. i dont have much money (hence the reason i have a v6), so i figure i can make do the best i can and buy used parts.</font>
Well , you have to ask Tiago and MustangEater about that. There are others on this board with fast 3.4's but I really cant rememeber right now.
94 3.4L Camaro A4 (Stock)
Old Aug 11, 2002 | 11:32 PM
viper98885's Avatar
Post
As soon as I get timeslips and dyno numbers, I will post em.
- Josh
If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com
'93 Camaro Hardtop, View my car here!
Co-Owner, American Muscle Motorsports, Performance Parts Company
Old Aug 12, 2002 | 02:22 AM
zlightning's Avatar
Post
I think the fastest 3.4 was a 13.9sec car.
[This message has been edited by zlightning (edited August 12, 2002).]
Old Aug 12, 2002 | 03:59 PM
MustangEater82's Avatar
Post
www.firebirdv6.com/timeslips
go there, you'll see some people times, jsut have to scroll down the the 3.4Ls.
I am one of the quicker, stock blocked and non-power adder guys.
I have a homemade intake, jsut some PVC piping, rubber drainage tubes, all parts form home depot, and the biggest cone filter I could find.
my exhasut at the moment, is pretty ghettoed, but I jsut needed a muffler on the car, no muffler was killing my ears.
I have a $15 thrush muffler, at the end of my Y-pipe, last time I ran it at the track I ran a 15.809, and it was about 80 degrees and very very humid out, I bet on a cold cold dry night, I could sneak another tenth and a half out of the car, if tractoin doesn't become a prolbme form then.
I have Accel universal fit wires, $25 ones form discount auto, I have AC dleco rapidfire plugs.
I have asp underdrive pulleys, and am currently only running hte crank pulley, the alt pulley is in my trunk, I might try hookin it back up agian some day.
Lt1 driveshaft, and 3.42 gears, complete with 4 wheel disc brake swap.
And i have a 5-speed.
I also have some suspension stuff that is wonderful but its pricey and doesn't really give the car more power jsut helps it drive.
Most important thing in my opinion is the car is tuned up.
-When was your fuel filter replaced
-how old are your o2 sensors.
-any exhasut leaks, check the EGR, if its leaking
-Flush the motor next oil change
-Whats your oil pressure like?
-run Seafoam, thorugh your vacum lines
-abotu where does your car idle at?
-run fuel system cleaner
-how is your PCV valve?
-are your valves ticking?
-Clena your throttle body really well, its easier to do it with it off.
You can combine some of these things, to save you time, like when you change the coolant, and flush radiator, you cna do a throttle body bypass, and pop the throttle body off and clean it up.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Rapidfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys, 160* stat
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
15s are cool!
AIM: MustangEater82
Old Aug 13, 2002 | 12:14 AM
Tiago's Avatar
Post
I have some stuff...
BADBIRD
94 Firebird 3.4L 5spd
I got TURBO, I got TURBO, YAAAAAYYYY........
http://tiago.phxchevy.com
AIM: Tiago 94FB
DOWN WITH THE SICKNESS
SICK-SIXX
Old Aug 13, 2002 | 02:37 AM
All_InTheRED's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Tiago:
</font>
......that's the understatement of the MILLENIUM.......and its just started!
.......I just wanna know who let the "nut" have a "hair dryer" on the street
Enjoy buddy!........just remember until you hit 30pounds.....its all just childs play!:
On the other hand, I can say I have the one of the slowest camaro's around.
Max
'95 Camaro V6..BB Triflo quad-tip catback, 180 degree Themostat, WaterWetter, K&N Air Filter, AC Delco Rapidfire Spark plugs, TB-Bypass, BMR Chrome-Moly STB, Front & Rear 1LE Sway Bars, 255/50/16 Eagle GS-C & F1 Steel, Dark Tinted Windows. Fog-lights on when Hi-Beam On Mod done tooooo.
www.home.earthlink.net/~airspeedy2
'99.5 F-250 SuperDuty CrewCab,PowerStroke Diesel, 2wd, Torreador Red, TS Extreme Chip & LPG, BTS Tranny & Converter, Maddog Stage 2 Injectors, TTS "Hybrid" Turbo (35psi max. boost), Detroit Locker ......14.2@99mph. 436rwhp/869ft.lbs.
...lets just say its not stock.....well DUH!
Old Aug 13, 2002 | 03:55 AM
Post
hey all in the red
have you given up on the 3.4 or are you stil looking to get it running better?
Best R/T .507
Best 60' 2.078
15s are cool!
AIM: MustangEater82
Old Aug 13, 2002 | 10:43 AM
Post
<font face="Verdana, Arial" size="2">Originally posted by MustangEater82:
hey all in the red
</font>
Its just that I have been having sooo much fun with the truck, I know the camaro has fallen behind
What you got in mind?
Its just that it seems that to get the 3.4 to run hard, would require engine work and/or nos.....neither I want to get into.
..but then again.....I have a extra Garrett T-38 turbo from the truck..hmmmm???
BUT as for the other stuff, I have most of it (CAI, Catback, etc). Plus I dont' want to drop a ton of cash into a car that is worth about $4000 bucks at resale time.
Max
[This message has been edited by All_InTheRED (edited August 13, 2002).]
Old Aug 13, 2002 | 03:20 PM
Tiago's Avatar
Post
hey max, that turbo would wake it up quite well,
BADBIRD
AIM: Tiago 94FB
SICK-SIXX
Old Aug 13, 2002 | 03:38 PM
camaros_4_lfe's Avatar
Post
hey mustang eater where did u get ur 4 wheel disc brake conv. from?
Old Aug 13, 2002 | 03:41 PM
Post
I know what you mean. I keep teling myself not to put any moeny into my car but at the moment I am wasting money on bolt ons, that I could easily replace and resell.
I just think there is a bug in your car that needs to be tracked down.
I mean it could be something small like a bad tps, thats sending wrong info to the computer causing trouble?
Best R/T .507
Best 60' 2.078
15s are cool!
AIM: MustangEater82
Old Aug 13, 2002 | 03:52 PM
Ryan94V6's Avatar
Post
Hey MustangEater , Im installing Headers , exhaust , CAI, and an 160 degree thermostat. What do you think I should run in the 1/4 after I install all of this. Oh and soon I will be getting 3.42 gears and underdrive pullies. Will I be any faster then?? I really wanna break into the 15's!!
94 3.4L Camaro A4 (Stock)Z-roc Big Block Hood ,RS 3 Piece spoiler.
Old Aug 13, 2002 | 10:15 PM
Post
I would assume you would be.
I would go with a 1 piece driveshaft also, lt1 steel ones are pretty damn cheap.
Personally I think most anyone with a 3.4L should check out there coils and clean up all the terminals, and update there ignition systems too. Not deathly important to upgrade it but just mke sure everything on the cr is fully functional.
Old Aug 13, 2002 | 11:02 PM
Ryan94V6's Avatar
Post
</font>
Thanks alot for the information !!
