question.....
Old Oct 21, 2003 | 07:15 AM
vz125dude's Avatar
question.....
i have a 98 a4 camaro. i like playin with the gears. i have 1 2 d od n etc... is it ok to downshift from d -2-1 or could i screw up my trans by doing that??? and another question my friend has a 2000 a4 bird and he doesnt have od so his goes 1 2 3 d n etc... and i like the fact of having control of the 3rd gear, how could i make mine like that, or is that impossible with me having od???
Old Oct 21, 2003 | 09:36 AM
faddis's Avatar
if you want control of the gears put in a manual trans
Old Oct 21, 2003 | 01:58 PM
vz125dude's Avatar
someone else please, not the smartass above , but seriously will it hurt my tranny if i downshift????
Old Oct 21, 2003 | 03:29 PM
camaro6's Avatar
You will screw up your tranny if you shift into 1 doing anythign over 30. Its probably a bad idea to shift them down. However, if your at a redlight, and shift up(1,2,D,od,) then you should be fine doing that.
Old Oct 21, 2003 | 04:07 PM
99blackSS's Avatar
Your D is the same as 3rd. Down shifting isn't good for the car.
Old Oct 21, 2003 | 08:49 PM
vz125dude's Avatar
thanx for the info, alot of times ill start in first and shift to second but have to slow down too like 10-15 mph and **** down into first....but if it hurts the tranny then ill just stop doing that.
Old Oct 21, 2003 | 10:06 PM
Chrisz24's Avatar
I messed up my first car doing stuff like that, lesson learned? LEAVE IT IN DRIVE!
I only use any of the other gears If I am driving on heavy hills or in snow.
The 1,2,3,D is the same as
1,2,D,OD
NVMYZ28
Jul 13, 2009 11:08 PM
Alicia
Aug 14, 2008 09:19 AM
Z28Wilson
19
Aug 25, 2007 06:54 AM
QCKZ28
Jan 14, 2004 02:06 AM
