overheating... i think
okay, i just bought my V6 1998 camaro and for some strange reason the temp gauge keep slowly moving up then back down and does that the entire time im driving (while sometimes "overheating") when i stop to check then engine feels like its at the normal temp. i just replaced the thermometer and radiator but it continues to do it. my guess is it has something to do with a short in the electrical but i dont know to much about cars other than the basics. can anyone help me out?
Re: overheating... i think
It usually moves like that when it's low on coolant. Check for leaks. Has the intake manifold gaskets ever been replaced? Common issue among GM coolant leaks. Replace with the better Felpro gaskets. In order to get all the air out of the system I know the front wheel drive 3800's have bleeder screws on the thermostat housing. You need to do this while it's running. Crack the bleeder screw open and top off the radiator.Close the screw when no more air is coming out.
Drowned
Apr 8, 2006 12:42 PM
