No Power...what Do I Do?
got my car back from the shop today....just got front suspension redone....
now my car wont get past like 50...i can put the pedal to the floor and it takes liek 10 minutes for it to even hit the next gear,....rpm's go so slow.....no power whatsoever....any ideas what could be the problem?....there is a slight oil leak around my passenger side head or something around there...just a slight leak though...no blown gaskets i dont think...please help fast...
IMO, if it revs alright on parking or neutral, but you have trouble with the gears, it might be a shift solenoid, as I have always said, go to auto-zone, of your place of choice and get it scanned for codes. and will take it from there.
i'm going to have to agree with atl2001, I had a problem similiar to that. would be running like a 2 cylinder. If it's not that, then you might wanna check the plugs, wires and coil. If it has hesitations starting too, then to fix that problem mine was the fuel pump and fuel filter. diagnostic check helps out alot too.
