My stupid speed limiter with 410 gears!!!
I have a 98 v6 auto camaro that had a speed limiter set at 109. but since i added 410 gears the stupid things kicks in at 90 now. hypertech doesn't make anything and the scu2000 will not work with 410s. i was thinking of finding a computer from a wrecked camaro to see if that would work. what do you guys or girls think i should do.
Buy this: Jet SCU2000
I thought the hypertech thing did...
ohh well I haven't tried it but in theory hooking up a toggle switch to the VSS sensor you may be able to unkook your speedo, everytime you swithc it off... Your speedo will ot work, not sure if it will cause other problems or not.
But in theory it will work.
you would have to find a computer that was programmed for 4.10s and i dont think that will be easy to do. what about http://www.superchips.com? i really dont know though.
and even if hypertech did make a 98 V6 model it would not cover 4.10s. i bought it for my 3.73s and it does not program for 3.73s. luckily it does program fo 24 in high tires, which put me in the same ballpark with the speedo. but how weak is that- you would expect it to reprogram for 3.73s or 4.10s. why would i go from 3.42s to 3.08s? which is what it will program
Originally posted by Green G0blin
that jet chip you guys posted was only for 96+..mine is a 94..how can i get one for a 94?
i've got a switch on my vss........works, according to online calculators, i got up to around 123-124, ran out of room, but it wasn't climbing very fast. don't know how fast i could actually go.......rambling, sorry.......but yeah, the switch works, and takes less than 20 min to do
By the way, what do the 4.10's feel like
