My DRL's are not functioning
Old Apr 12, 2003 | 01:04 AM
HAZ-Matt's Avatar
Post title says it all. The turn signals and parking lights are working, but the DRL's aren't shining when the lights are off. Any suggestions on what could fix it? I have no idea what the problem could be.
It's a 2000 Firebird.
Old Apr 12, 2003 | 09:09 AM
kahouna23's Avatar
Does your car have the automatic lights. You know when it's dark enough outside, the lights automatically turn on? It could be a fuse, or most likely the switch connected to the E-brake. Check the wires for power. You do know that the turn signal and DRL's are two seperate bulbs within the same housing. Turn signal goes into the housing from the back and the DRL goes in from the top. Just FYI
Old Apr 12, 2003 | 09:54 AM
V6 Punk 93's Avatar
On my friend's 98 WS6 it's the same bulb. I know this for a fact because I helped him replace them.
Old Apr 12, 2003 | 04:58 PM
HAZ-Matt's Avatar
Hmmm. No i was not aware that they are separate bulbs. I thought it was one multifilament bulb.
I do not have automatic headlights (I have a Firebird).
Old Apr 12, 2003 | 07:46 PM
kahouna23's Avatar
Oops....there I go again not reading the entire post. I'm really sorry. Though we were talking about a Camaro. I'm officially the CZ28 board retard....
Old Apr 12, 2003 | 08:29 PM
HAZ-Matt's Avatar
Well as long as you are big enough to admit it
Just got back form replacing the bulbs. The turn signal/DRL's/parking lamps are the same bulb. It has two filaments. Bulb change didn't solve the problem. Looks like I might have a faulty E-brake position sensor (although the dash reads BRAKE when it is on) or possibly a bad BCM or DRL module.
marlar98
Sep 12, 2018 07:18 AM
CARiD
Sep 30, 2015 05:44 AM
4586
Sep 6, 2015 03:10 PM
4586
Aug 24, 2015 11:04 PM
Aug 5, 2015 08:35 AM
