lowering springs
Old Mar 15, 2004 | 04:26 PM
DontMixWithRice's Avatar
lowering springs
what are the best lowering springs available for a 95 3.4l.
pros.
cons.
thanks
Old Mar 16, 2004 | 01:42 AM
oil pan 4's Avatar
YOu can get eibach or hower ever you spell it, the part of the edelbrock co.
I have herd that these are some of the best.
Pro's are you are lower and the ride is a little stiffer you get a good chance to change out your shocks and struts while your at it. Lower center of gravity and pull more G points on a skid pad.
Con's are you have to spend money, you need some tools and it's not free like cuting them (bad idea any way).
Old Mar 16, 2004 | 11:44 AM
J0HN D's Avatar
I bought Eibachs for mine.
Pro's - well known name, reasonable cost.
Con's - the rear will sit close to the bump stops.
Coilovers are a possibility
Pro's - very adjustable as far as height goes. You can also get stiffer or softer springs, depending on what you want. (handling, lowering, comfort)
Con's - cost. More complicated to choose the right combination.
Old Mar 17, 2004 | 01:32 PM
94BlackBowtie's Avatar
I would recommend the Eibach Pro-Kit.
I know from experience the pros and cons of that paticular kit on a 1994 V6.
Pros - Lower ride (of course), better handling, improved ride (in my case), hides wheel gap, million mile warranty.
Cons - INSTALLATION! This isn't fun at all really. You will need some spring compressors, and PB Blaster (along with the other wrenches, etc.)
You can get a Pro-Kit for under or right at $215 shipped easily from eBay - just look for "Camaro Springs". Don't get a no-name brand - stick with the Eibach's - they are worth the extra $$$.
Old Mar 21, 2004 | 01:20 AM
chesee48's Avatar
yea, i recommend the pro kit also.... do not get the sportlines unless you like to be slammed! i had them and they looked nice, but it rode rough...
Noenav
Mar 1, 2019 07:38 AM
thenewkid
Apr 12, 2015 07:42 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
