Injectors?
Old Jun 27, 2004 | 08:17 PM
94/97project's Avatar
Injectors?
Been wondering I have a 3.4l w/ stock 16lb injectors and was wondering if the 22lb injectors out of a 3800 will fit and/ or work? anyone know?
Old Jun 27, 2004 | 08:27 PM
or will the LT! injectors work?
Old Jun 29, 2004 | 01:35 AM
weak95bird's Avatar
I think the lt1's are plug and play :P
Old Jul 1, 2004 | 08:23 AM
oil pan 4's Avatar
You don't realy need them unless your running lean.
If your car is stock you realy don't need them. You will run rich and waste gas.
Old Jul 1, 2004 | 06:47 PM
thanks Thats what i needed to know I'm runnen pretty good with the stock ones, I squeezed the slp CIA from an LT1 on her opened up the exhaust a lil bit and had my tranny tweeked about 30k ago I think its time for a flush though. It was giving me some problems the month because my old man drove it for a while and put crap gas in it an it clogged one or two of them. Had em cleaned an now shes runnen better. I found alot more of us 3.4 6ers out there trien to keep the gas and ins $$ down while tryen our damndest to get the HP up......
Old Aug 17, 2004 | 04:59 PM
Re: Injectors?
Dose anyone have or need to get rid of a set of injectors or even a 3.8l motor????
Old Aug 20, 2004 | 06:26 PM
Need4Camaro's Avatar
Re: Injectors?
I gatta know, how can you put bad gas in a 3.4 V6 that runs off of 87 Octane... I'm not calling or anything but I'm just curious.
Old Aug 20, 2004 | 07:16 PM
Re: Injectors?
from one of those hole in the wall gas stations that sells more smokes than it dose gas.
Old Sep 14, 2004 | 01:42 PM
Re: Injectors?
found and solved the problem within the fuel line, plugs, and wires all better and has never run better. thanks for everyones input.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
