Injectors?
Been wondering I have a 3.4l w/ stock 16lb injectors and was wondering if the 22lb injectors out of a 3800 will fit and/ or work? anyone know?
or will the LT! injectors work?
I think the lt1's are plug and play :P
You don't realy need them unless your running lean.
If your car is stock you realy don't need them. You will run rich and waste gas. |
thanks Thats what i needed to know I'm runnen pretty good with the stock ones, I squeezed the slp CIA from an LT1 on her opened up the exhaust a lil bit and had my tranny tweeked about 30k ago I think its time for a flush though. It was giving me some problems the month because my old man drove it for a while and put crap gas in it an it clogged one or two of them. Had em cleaned an now shes runnen better. I found alot more of us 3.4 6ers out there trien to keep the gas and ins $$ down while tryen our damndest to get the HP up......
Re: Injectors?
Dose anyone have or need to get rid of a set of injectors or even a 3.8l motor????
Re: Injectors?
Re: Injectors?
from one of those hole in the wall gas stations that sells more smokes than it dose gas.
Re: Injectors?
found and solved the problem within the fuel line, plugs, and wires all better and has never run better. thanks for everyones input.
