help i need to know what gears i have
Old Aug 22, 2002 | 11:51 AM
mywhitez's Avatar
Post help i need to know what gears i have
my buddy has a 97 camaro with an auto and he wants more lowend so i was wondering if it has 2.73s or 3.23s? if its a series 2 carrier is there a place where i can get richmond thick gears? or does this car have a series 3 carrier. is 3.73s a good gear for these cars?
thanks
jay
Camaro 13.7@101 cai and flowmaster catback more to come.
86 mustang 12.31@113.84 on nittos
Old Aug 22, 2002 | 09:42 PM
94Camaro6cyl's Avatar
Cool
Screw 3:73's go with 4:10's....
Old Aug 22, 2002 | 10:33 PM
shortdog273's Avatar
Post
If he does alot of racing go with the 3.73s. Otherwise get 3.42s.
2K BLACK FIREBIRD 3.8 A4 (Stock 3.42 Gears & LSD)
With Intake, Exhaust And Suspension Modifications..
MOFBA/FAStLouis Member... 1/4 Time: 14.98 @ 89.66
Old Aug 23, 2002 | 05:47 PM
nikkev's Avatar
Lightbulb
The door codes are:
Gu4 - 3.08's
Gu5 - 3.23's
Gu6 - 3.42's
The V6's don't come with 2.73's at all.Also,3.23 and higher (numerically) are a 3 series carrier while 3.08's and lower are 2 series.Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
Old Aug 23, 2002 | 11:21 PM
blue95's Avatar
Post
auto typically came with 3.08's series.
If you are going to be doing a lot of drag racing then go with the 3.73's. At highway speed you car could be a 2500 rpms easily. They had a ungodly amount of low end and will put you into your high gears fast and may not be a good thing because 3rd gear in auto's aren't the greatest. Your 60' times will be quicker but not as much improvement in your overall 1/4.
I would go with 3.42's if you just want to get some more power to your wheels and drive around town without your motor. It will give you a decent amount of low end and torque although it will cut down on your top end. Max speed roughly 90miles per hour? I have heard that although you probably could get higher easily. Anytime you switch your gears out you will have to recalibrate your computer(if the dealer does it $20+-?).
Unless you plan on getting a new motor in the next couple months don't go with 4.10's. Thats a whole different ballgame.
There are several guys on this board and others(see link in sig) that have switched to 3.42's and 3.73's. I would reccomend that you change your differential to a posi or . You will get more out of your gears that way. Good guy to talk to is Mustangeater82 or shortdog. Tell em blue95 sent yah!
If you own a V6 Camaro or Firebird you need to be here!
http://www.fbodyv6.com/index.php
[This message has been edited by blue95 (edited August 24, 2002).]
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
