Gauges
Old Jan 28, 2004 | 08:56 AM
deadmeat2004's Avatar
Gauges
Can you put the 150mph V8 gauges on the V6, if so what changes will have to be made? I have seen firebirds with this so wondering if you can on the camaros.
Old Jan 28, 2004 | 03:19 PM
ImportKILLER's Avatar
They won't read correctly.
I'm pretty sure you would need to reprogram...
Old Jan 29, 2004 | 08:29 AM
reprogram, well that mean i could take it to the dealer and they can do it? cheap or not?
Old Jan 29, 2004 | 03:56 PM
Reprogramming...eh...I had a hard time finding a dealership that would reprogram my PCM for 3.42 gears when I still had 3.08 gears. Some find it hard to find a dealer willing to do it, some find them easily. Depends I guess.
I'm sure someone has done the gauges and will chime in...I'm just guessing you would need reprogramming since the needle would be at the same spot but the gauge itself would show a different MPH reading.
Old Jan 29, 2004 | 06:51 PM
99blackSS's Avatar
I remember this being discussed a long time ago, I couldn't find it in a search though.
I forgot what all was involved, a reprogram at the very least.
Old Jan 30, 2004 | 03:30 AM
wicked98v6's Avatar
This has been a topic of discussion. It should switch out without modifications. The Speedo will be accurate the Tach will not due to the difference in cylinders....
Old Jan 30, 2004 | 09:09 AM
so u are saying that u wont have to take it to a dealer for reprograming...? I know in my dads pickup he didnt have to because it was all digital but?
Old Jan 30, 2004 | 01:06 PM
99blackSS's Avatar
That's impossible, simply putting in V8 guages would not work because the numbers are in different places, on the Z28s when the needle points straight up it points to 80mph. On the V6 (3.8l at least) when the needle point straight up it is at about 65. At 120mph on the V6 gauge the V8 gauge would read 150mph...
The tach should be ok.
Old Jan 30, 2004 | 02:07 PM
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
