Freeze plug spraying coolant ?
Old Jun 4, 2008 | 02:15 PM
Catwizard's Avatar
I just replaced my gf's (1995 camaro v6 3.4) water pump. I see now that water is spraying out to the left of the pump kind of behind the belt tensioner. Please tell me this is just a freeze plug.
Old Jun 5, 2008 | 05:47 PM
95camaroinok's Avatar
Probably--- There is a freeze plug directly below the water pump bolt that is farthest to the left when facing the engine. Should be accessable by removing the tensioner. Not as big of job as the water pump itself.
Old Jun 6, 2008 | 12:12 AM
Catwizard's Avatar
Thanks I haven't had the time to look at it again and it is hard to see. It's almost funny that it was all that was wrong now that I basically took everything off the front of it to replace the water pump. It is going to be ridiculously easy compared to all that stuff. Before it was barely trickling there and I just assumed it was the wp weep hole, or a leaking gasket.
Old Jun 14, 2008 | 05:30 AM
Checkin in to see if you got this taken care of. Let us know.
blac94Z
Feb 15, 2021 09:43 PM
charchri4
Apr 14, 2015 06:40 PM
warmeck
Mar 1, 2015 08:47 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Fatdog2
Feb 13, 2015 08:19 PM
