flywhell, pulleys etc...
Old May 19, 2003 | 02:34 AM
YounGDeezY's Avatar
A friend of mine said i should get some aftermarket pulleys and after thinking about it i should. i know that Grand Prix's have 3800 Series II Engines. I dont know about the bolt-ons/internals of them. could i buy an aluminum flywheel, water pump, alternator pulley and is it worth buying. im tryin to shave a little weight, build my ride stronger and produce better revability of the motor. if this is something i can do, then what type of pulleys should i replace? what type should i get as well underdrive or overdrive?
Old May 20, 2003 | 12:04 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
an overdrive pulley? no, that would be bad, i dont think they even make such a thing.
overdrive is for your car's trans not the crank pulley
all the underdrive pullies are basically the same
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
Noct
Jul 14, 2015 01:18 AM
