evac sys wnt pass smog
Old Mar 31, 2007 | 07:55 AM
throbbin4fun's Avatar
Unhappy evac sys wnt pass smog
how do i go about trouble shooting and fixing it or can it be a sensor ive got a 96 RS 3800 the error code is p0441 purge flow incorrect is it the canister or the pressure control valve i did a little research and think its the canister
Old Mar 31, 2007 | 09:15 AM
2000GTP's Avatar
Is there an SES light? If so, a scan and the accompanying codes would be a good start.
Old Apr 2, 2007 | 10:23 AM
smithtim's Avatar
I had the P0441 recently and if I remember correct it turned out to be the actual valve which was something like $15 at the dealrship and was an easy fix (but think they called it a purge switch or something like that).
Anyways it could be that or I have heard to people having problems with the actaul canister or lines.. probbaly best way to do it is pull of the valve and look to see if there is any build up in there if so that points to problems with the canister or lines; on the other hand if it is clean in there it most likely points to the valve itself being bad....
David Dempsey
Mar 12, 2016 12:42 AM
drt
Sep 27, 2015 04:39 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
john henry
Aug 14, 2015 08:33 AM
colts0455
Jul 8, 2015 12:21 AM
