Enigne overheating?????
Old Oct 30, 2003 | 02:19 PM
96 camaro 4 life's Avatar
I'm hoping someone could help me with my problem...My temp gauge is goin nuts. It used to be at about 180 or so, now it goes up and down b/w 210 and about 225. After starting the engine, instead of it taking like 5 mins to heat up, the engine temp gauge will just shoot up in about 1 min. It started about a week ago so i checked and added a bunch of coolant. Then my coolant started to look from somewhere below the engine, it was gettin onto the belt and gettin onto other parts of the engine. I've heard that it could be my heater core and i did have a leak in the pass side, but i'm pretty sure that was just water, cuz it has only happened when it rained. Does anyone have absolutely any idea as to what my problem could be, i would really like to get this solved asap, cuz at 730 am, its cold without a heater!!
Old Oct 30, 2003 | 04:30 PM
Marky82's Avatar
So your engine is running hot and you dont' have heat? Not sure about the lack of heat but my engine started running hot when the water pump started to go...also you might might to replace the thermo and flush the coolant system
Old Oct 30, 2003 | 04:39 PM
camaros_4_lfe's Avatar
check
#1 coolent
#2 thermostat
#3 waterpump
should be one of those but could be a restriction somwhere especially if someone used stop leak in it
Old Nov 3, 2003 | 01:43 PM
k, i'm sick of this problem, i'm gonna just take it in to get checked out. Every time i wanna drive i've gotta fill my coolant up and its a nuisance!!
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
walter1234
Oct 28, 2002 12:05 PM
