ECU Programming for Turbo
Old Apr 7, 2003 | 12:49 AM
MonteCarloSS's Avatar
I'm going to turbo my 3.4. I know what I'm doing, and I have everything I need on hand. The biggest obstacle for me, at the moment, is figuring out how to program the PCM to deal with boost. Is there a way to incorporate a 3-bar map sensor into my stock ECU w/ some programming, or do I need to go aftermarket standalone? If so, how much of a PITA would a halltech system be to hook up? It doesn't look that bad, since it uses DIS and can be set up for the SFI. Is this sort of a bolt-on, in a weird way?
For those of you who have done turbo set ups, how did you get the computer to recognize and compensate for boost?
Anyone who's turboed a 3.4-- do you have any useful links, etc.? I'm mostly interested in the plumbing, I think I'm going to fabricate my own 3.4l turbo header.
Old Apr 7, 2003 | 01:46 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
cant you just use an FMU that raises the line pressure for your fuel with each pound of boost you develop? that is how we did my friend's probe
Old Apr 7, 2003 | 04:07 PM
Yeah, you can. But that doesn't take RPM and timing into consideration. I want something to work perfectly. I'm thinking about using the Haltech E6GM, if it will replace the ECU in my 94 V6.
SEOJustin
Sep 24, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
