Dtc E504, E545, 7700, 7900 & 8100
Old Oct 2, 2006 | 11:48 AM
DMGroh's Avatar
While chasing down a misfire problem (now isolated to 1 particular injector), I am also getting these codes on my reader....but not on a consistent basis.
Neither the code book with the reader, nor the Factory Manual (at least what I can find) shows these codes.
Now, after swapping No. 1 & 3 coils & injectors, I'm getting the red "brake" and "ABS inop" on the dash....but not all the time. If I do an off-on of the ignition, the brake/ABS resets but usually comes back on after about 1 mile. Stepping/not stepping on the brake has no effect in setting this particular warning.
Only reason I mention swapping coils/injectors is that I was working right near the ABS module. Thinking I bumped and disturbed the connector, I pulled off the connector to the module and sprayed it with electrical contact cleaner and reinstalled the connector, but still getting the warning.
I don't have the scan tool mentioned in the FSM that will tell me if the ABS Module is defective...which I doubt. I suspect a loose electrical connection.
2000 Camaro V6 auto/air/4whl disc/ABS (No Traction) 144k miles
Thanks for any help or suggestions.
Old Oct 2, 2006 | 02:49 PM
GRNcamaro's Avatar
Re: Dtc E504, E545, 7700, 7900 & 8100
im not really sure of your problem but the year of the car might help others determin the problem. good luck with your car
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
