Drum to Disk Brake Conversion
Old Apr 11, 2003 | 09:23 PM
Indelibility's Avatar
Question Drum to Disk Brake Conversion
The big Drum Brakes in the back of the V6 is a dead givaway that it's not a Z, and they are ugly. What do I need to convert my rear Drum Brakes to Disk Brakes?
Old Apr 12, 2003 | 12:13 AM
Red96CamaroRS's Avatar
rear end
bro i was thinking about doing the same thing and heres the easiest way.
just buy a complete rear end from the same year car as yours. benefits are different gears and disks.
with that, i heard your going to need a longer e-brake cable too for some reason. with the gear change, you might need to have your speedo re calibrated.
with having disks in the back now, your going to need a new porportioning valve to get fluid back there.
it sounds like alot- but its alot easier and worth more in the end imo.
hope that helps-
Old Apr 12, 2003 | 01:54 PM
94Camaro6cyl's Avatar
I wish I had the $$ to do that conversion, the drum brakes fawkin suck! Good luck man....
Old Apr 14, 2003 | 06:52 PM
MustangEater82's Avatar
I never used a proportioning valve, my brakes stop better then before when I had drums, it bolts in, jsut use 93-97 lt1 rearend for 93-07 v6s, and 98-02 ls1 rear ends for 98-02 v6s.
you can use a ls1 rearend on a 93-97 but the rear discs will be larger, will be functinal and streetable but not ideal.
You do need a differnet e-brake cable jsut get one of a z28 or a 4-wheel disc brake v6, and year will work, you need form the point where it splits from one to two, cables back.
and once again, i never used a proportioning valve soem said I needed it soem say i didn't I haven't used one, and my car stops better and I get even brake pad where, come this august it will be 2 years with this rear end on my car. Has one road race, 7-8 autocrosses, and maybe 90 passes on the drage strip on it.
Henson071
Dec 30, 2015 09:55 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
Boss002
Jul 24, 2015 10:47 AM
hcarrickz3
Jul 21, 2015 08:46 AM
