DRIVESHAFT!!! My 98 Camaro
Old Mar 4, 2005 | 11:30 PM
Orange98Camaro's Avatar
ok, i made a big mistake the other day... what i did isnt the problem, lol, the problem is what is wrong.
It starts off by my dumbass takin my car out after a day of snow (no snow on the road) but still kinda chilly out. When I was on my road, i took a turn and there was a patch of ice on the ground, i guess my speedo got up to about 90 then I caught traction (heres the bad part) at first i thought it was my rear end that might have stripped, but then i started to pay attention to the noise better and it was a clanking sound (when put in ANY gear except park) so i threw it on jackstands today, started it up and looked under there. Either my driveshat is a 2 piece, or i made it one... here is where im confused on what part to buy, the transmission turns the yoke and the U joint turns the driveshaft (first half), then i look toward the middle of the shaft and notice like it isnt connected some how. you can see where grease had speckled where the broken part is.
I mean after the farst half of the driveshaft nothing else turns, it just makes a nasty constant clanking noise.
PLEASE TELL ME WHAT I NEED!!!
thanks
Chris
Old Mar 5, 2005 | 12:48 AM
MustangEater82's Avatar
Re: DRIVESHAFT!!! My 98 Camaro
YOu have a 98?
I cannot remember, but alot of v6s had 2 pieces, and alot had one piece driveshafts...
Either way if your driveshaft was broken, part of it would likely be laying on the ground.
If you have a 2 piece, and its not broken, I'd consider upgrading to a 1-piece steel, it will give you less problems down the road.
Old Mar 5, 2005 | 12:50 AM
brink's Avatar
i have a 98 .. ill look at mine tomorrow and tell you whats up
Old Mar 5, 2005 | 01:10 AM
JJayzX's Avatar
it should be a 2 piece so just get a single piece aluminum one from a v8 should be samething and its lighter so you will lay more power to the pavement.
Old Mar 5, 2005 | 03:21 PM
ok... lets say if I do get the new driveshaft (or used from salvage yard) what would it cost? and lets say i didnt get it and i wanted to repair my 2 piece, what part would i need? BTW, thanx alot for responding to my problem
Chris
Old Mar 5, 2005 | 03:35 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
i got a steel DS from an LT1 car for 5$ from a friend, expect to pay around 20$ for one... the steel ones are cheap
Old Mar 5, 2005 | 04:03 PM
really, kicka$$... I also found one on ebay in my area for like 20 bux and its aluminum... there is like 1 day left on the bid... thanks, and if anyon else has anything to add, please do
Chris
Old Mar 6, 2005 | 09:50 PM
JJayzX's Avatar
also with getting a used driveshaft is get the balance checked at least and thats all really.
HectorM52
Jul 30, 2017 11:46 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
