disk brake conversion
Old Dec 29, 2002 | 10:54 AM
onoiocoko's Avatar
ive searched for hours and hours. welll actually about 2 minutes but i couldnt find anything. if i was going to convert my rear drums to z-28 rear disk brakes, would it be a direct bolt on. i heard all i had to do was change the e-brake cable. but i heard that when people where talking about changing the whole rear axle so is a direct bolt on to my V6 axle?
Old Dec 29, 2002 | 01:30 PM
nikkev's Avatar
Cool
Yes it is a direct swap.All that's needed is an adjustment of the E-brake cable.I did this on my '95 V6 a while ago.
Kevin
Old Dec 29, 2002 | 04:49 PM
Red96CamaroRS's Avatar
im actually goin a step futher- Im swapping a complete rear from an Auotmatic 96 Z28. I believe all i need is to get a longer e-brake cable and a new porportioning valve- possibly new master cylinder.
Old Dec 29, 2002 | 05:48 PM
nikkev's Avatar
Neither of those are needed for the swap,unless yours is bad of course
Kevin
Old Dec 29, 2002 | 08:04 PM
HailDented95's Avatar
Exclamation certain conditions
I had a 97 rear axle swapped into my 95. I was told that for a direct bolt-in, make sure the year's are close. 1998 and above will not work in 97 and below, and vice versa.
Old Dec 29, 2002 | 08:25 PM
SixVi6-Camaro's Avatar
Heck I got a rearend from a 96 Z28 in my car and brakes from a 1997 and I drive a 1995 3.4l. You don't need a porportioning valve or master cylinder for the swap.
Go here to billy grahams..
that is where I got my conversion kit. it came with disks, calipers, backing plate, brake lines, all needed bolts, and parking brake cables.
John
Old Dec 30, 2002 | 12:56 AM
Team Untouchable's Avatar
And do you guys get like 1000000% percent better braking power than with the drums in the rear. Ive done the 2 pisont LS1 upgrade in the front, but want to convert to rear discs also. How much was install?
Old Dec 30, 2002 | 11:31 AM
Yes there is a difference. the brakes feel a lot more solid. I believe the whole setup from billy grhams costed me I think under 275 and I did all the work myself. its worth it for sure for the imporved braking and aperance. DIsks look sooo much better then drums especially if you have rims wiht open spokes.
Old Dec 30, 2002 | 03:34 PM
onoiocoko's Avatar
how much did u other guys pay. from like regular junkyards to a personal seller on here?
Henson071
Dec 30, 2015 09:55 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
Boss002
Jul 24, 2015 10:47 AM
hcarrickz3
Jul 21, 2015 08:46 AM
