Is a computer necessary to change spark plugs?
Old Apr 21, 2004 | 12:17 PM
Kurt Crosbie's Avatar
I just changed the plugs and wires on my girlfriend's 96 3.8. Before I did that, I changed the o2 sensor on the #1 bank. (Afterwards, the SES stopped coming on) But now, the scanner says my coil is bad and the SES is coming on. Keep in mind, the scanner did not give a code for the coil until after I changed the plugs and wires.
My girl told me that some mechanic told her that you have to reset something with a computer after you change the plugs and wires. I don't believe this.
Old Apr 21, 2004 | 12:50 PM
2000camarostud's Avatar
just unplug your battery for about 15 minutes or so and see if that helps it. i havent heard of ever having to reset your pcm after changing plugs but hey, give it a shot and see what happens.
Old Apr 27, 2004 | 12:22 PM
HBHRacing's Avatar
there is nothing that needs to be reset after a plug change.
find out witch cyl or cyls is missing and see if they are on the same coil or not. I would be checking for proper gap on those 1 or 2 plugs as well as making sure that the wires are on the right plugs
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
