Compressor
Old Apr 15, 2007 | 08:04 PM
Choppers's Avatar
Compressor
My AC hasn't worked in a couple of years. Well i can't take it anymore with the Florida heat and when a compressor goes bad doesn't it start to leak? Also what the best way to see if its leaking?
Also this is a 3.8 V6
Old Apr 15, 2007 | 08:28 PM
nocturnalLT1's Avatar
It might not have anything to do with the compressor you may just have a leak elswhere in the system. Take it to a shop and have them charge the system and at the same time have them put some "dye" in it. The dye glows in the dark and in a few days you can search for any possible leaks with a black light.
Old Apr 16, 2007 | 08:56 AM
smithtim's Avatar
yeah they should be able to fill it with refrigerant for well less than $100... then it should work and last for maybe a few days maybe a few months. I had a similar problem last year and I was planning to get rid of the car as soon as I could afford a new one. So, last year so about mayish I filled it with refrigerant and it lasted until late October and then it was time for t-tops... of course it is really best and environmentally correct etc., to fix the leak and if I remember right they quoted a little over $300 to do that
its kind of tough to do AC work on your own
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
